vacuum problem | Ford Explorer Forums - Serious Explorations
vacuum problem
kwest159
elkins park, pa
94 xlt
i have a 94 xlt thats having some problems. engine shaking and loud whistle.
popped the hood and found the sourse of the noise which looks to be a missing vacuum hose. in the picture below it is right next to the hose marked 1. looks like just a nipple without a hose there. i cant find the hose or where it came from. checked the vacuum diagram but its hard to figure out because the car is stuck somewhere else. i know this isnt the best information but any ideas will help. thanks
http://www.chiltondiy.com/content/9131/images/89684g10.pdf
I would start by capping it off and seeing what happens. May be that it was capped to beginwith and the cap fell off. (happend to me on a 3.0 in a ranger)
I tried for days to figure it out, took it to Ford and they put a 5 cent rubber cap on there and charged me 50 bucks...lol Live and learn :D
Daniel
i tried running it with my finger over it. ran good for a minute the back to shaking. will try to cap i though, you never know. just need to get it home. thanks
look to see if it was a rubber hose that dry rotted and fell...like the one to the tranny (if so equipped)
Apparently its a constant vaccuum straight off of the manifold, so its not a valve activation line...could be the one that goes to the fireewall for the flapper in the heat-A/C system. Might go to the cruise..Ive seen the cruise on some Ford vehicles run by vaccuum....
I hope Im helping here.... :p:
Daniel
Pics from a 91 4.0 OHV.
Some of the ports are capped. If you have an automatic transmission, they have a tendency to blow the vacuum lines off when the modulator goes bad. If this continues to recur, that may be the problem.
