Valve Gasket replacement | Page 2 | Ford Explorer Forums
The locations on the vacuum tree don't matter so you don't need to worry about that..
IIRC the 92 has the following things connected via vacuum..
Automatic Transmission
Fuel pressure regulator
vacuum canister/air cleaner
Brake Booster (large hose)
Cruise Control (large hose)
The rest are capped off.. which means i believe 3 capped off lines.
~Mark
