wildcrisps
- March 3, 2002
- Navarre, FL
- 1995 Explorer EB
I have a 95 Explorer with 105,000 miles. I recently had my headgaskets replaced by the Ford dealer because one was leaking to the outside, no overheating occurred. They also sent the heads out for valve grind and guides. 1,200 miles after I got it back I noticed it needed a little more than a quart of oil. I brought it back and the dealer said that was normal, but it didn't do this before the head work. They did an oil consumption check and 700 miles later it had taken in a quart of oil. They said the oil consumption was normal. Compression was 175 all around and there was oil on the threads of the number 1 cylinder spark plug. The electrode had a whitish burn buildup, the mechanic said that was piston material because the oil ring was bad on the number one cylinder.
How did he know that? It smokes when I start it in the morning, and even at the dealership - they said that was normal. They say I have to have the lower engine rebuilt to stop the oil burning. It's odd that this sudden oil consumption started immediately after they did the head work yet they say it's the rings in one cylinder. The car runs fine with the exception of the oil consumption. Any help out there? Any suggestions?
