ventilation | Ford Explorer Forums
ventilation
marcus
The manual says to shut off, the heat and outside air place the switch to off position
and the lever to the far left. i still receive heat as if it were still on?
Marcus, what year is your truck?
92EB 2wd with chip and Flowmaster catback system.
Jim
"The older I get the faster I was."
It's a 91 sport <BLOCKQUOTE><font size="1" face="Verdana, Arial ">quote:</font><HR>Originally posted by xr600boy:
<HR></BLOCKQUOTE>
This was a design problem in '91-'93 Explorers. They fixed it in '94 by putting a heater control valve in the heater hoses. If you get the valve for a '94 Explorer and run a vacum line to it, it will shut the water flow off to your heater core. You will either need to find a wayto switch the vacum on and off or you will have to remove the vacum line when you want heat.
Rick Horwitz
Editor
explorer@4x4central.com
www.4x4central.com
