WBCarson
- October 19, 2015
- Dawsonville, Ga
- 2007 Sport Trac
I have a mouse in my 2007 Sport Trac! When i turn on the air or heat, it smells like mouse pee bad. Opened the hood and saw him run around. I cant find a nest. There is no cabin air filter.
We bought the truck and ive had to put some work into it and so far so good, (thank you board)but one thing i noticed about the VERY basic ventilation system is that i have no choice if i want to recirculate or allow fresh air in. I turn the system on, its always outside air. The button where a Recirculation button would be is a dummy button. I would assume that if the system is off that some outside door would close, but even with it off outside air comes through the vents. I can change between air conditioning and heat fine so i think that actuator/blending door is ok.
So, no door on the Sport Trac to close of the ventilation?
Does outside air come in from the cowl? Not sure how to remove the cowl anyway.
How does one get into the system? I cant find a diagram of the system
Thanks!
Thanks!
