NoogaX
- September 6, 2007
- Chattanooga, TN
- 1997 AWD Limited
Wanted to share my experiencce with every one. My X was running fine when parked the other night and the next morning would not idle worth a flip. Ran fine if I kept the gas to it but just would not idle. Changed the IAC and no difference. Started looking at wires, plugs and vacuum lines when I found a large vacuum tap cap laying under my intake manifold on the driver's side. Got to looking a little more (like standing on my head) and found a large tube behind the steel lines on the valve covers just the right size for the cap. Tube was part of a "T" that was screwed into the underside of the manifold. Put the cap on and no more rough idle. Didn't have time to follow the other end of the "T" (which had a hose on it) to see where it went but will soon. Cap was very loose so I put a small tie wrap around it and pulled it tight. Sarted the X and what a difference! Idle is silky smooth and the old girl runs like a new one. Guess this cap has been getting loose for some time and finally gave up the ghost.
Don't know if this will help any one else but wanted to give back a little for all I have gotten out of this site. Just for the records my X is a 97 Limited AWD with a 5.0L about 167K and I am getting about 18MPG around town.
