VERY squeeky door! | Ford Explorer Forums
VERY squeeky door!
red.EDDIE.4x4
Tulsa, Oklahoma
'93 Eddie Bauer 4x4
ok well im not sure if this is the right section...but if not im sure a mod will move it for me.
ive got a 93 eddie baur 4 door and for about...ah...2 months ive had a slight squeek when i open or close my drivers side door. and just recently its become really loud and quite annoying/embarrassing...
ive tried your regular ol' WD40 and that just seemed to make it worse, then i tried automotive oil, then i tried wheel bearing grease...nothing seems to work for more then a day.
i know this sounds silly but im sick of it.
if anyone knows something to do or use please speak up!
thanks guys :salute:
Silly question, but have you been able to isolate the noise to a certain hinge? The box-style hinge most often makes noise on my ST. I use a waterproof polyurethane lubricant (the same stuff you use on bushings) so prevent the WD40 wash-off and white lithium wear-off.
Well think I've got the source pinpointed at the lower hinge, near the little plastic rolling piece. It seems only to squeek when there is pressure on it. And I just de-greased the whole door jam and I'll see what happens.
I use silicone spray on my hinges and it takes the squeaks out spray on open and close like 10 times and your set.
well the de-greaser worked for about 2 days. the hinges were dry and it didnt creek/squeak/ or groan at me. then this afternoon it started making a groan...great...ill try some silicone spray.
