Very weak parking break | Ford Explorer Forums
Billy177
Redding CT
99 Explorer XLT SOHC 4x4
my parking brake is very weak do i just adjust it like drums or is there another way.
I think they are made to adjust everytime you set the brake. When is the last time you replaced your back brakes. The shoes could be worn out.
Try adjusting it... it has the spindles you turn exactly like drum brakes. If it still weak replace the shoes.
I also have a very week parking brake and would like to replace them. How tuff of a job is it to replace the shoes? Why couldn't it work from the pads like cars do?
Replacing the pads in there is very easy. Pads only cost around 20 bucks and it takes less than an hour to do the job. I did it a few months ago and it was much cheaper and easier than I thought it would be.
DasFrem
Where did you buy the pads??
Napa will have them. Thats where i got mine, and i just replaced my pads about a month ago as well. Pretty easy task.
Dont know if its a silly question, but do they sell the shoes in sets of 2 or 4?? I mostly order online and that info is usually not given without having to call.
I got mine as a set of four shoes
THe 2nd Gens use a dual system in the rear. It has both Disc (for regular braking) and drum (parking brake). It's a good idea to always check the shoes for the drum brakes at least once a year. SInce most people never use their parking brake these tend to be neglected. the parking brake operates exatly like the parking brakes on the older X's with rear drum brakes
