Vibrates a bit only in park or neutral | Ford Explorer Forums
tlee128
2003 Mountaineer V8
Any ideas?
It's a 2003 Mountaineer AWD 4.6 with 140K miles. When in gear, no vibration at all. Things I've changed so far (was going to change anyway as part of high mileage maintenance): oem coils, platinum spark plugs, oem iac valve, oem mass air sensor, cleaned throttle body.
Could it be motor mounts?
Btw, anyone know how much to change all 3 motor mounts?
Thanks.
What are the RPMs at idle when you have the vibration?
750 rpm at idle, very steady. If you give it a little gas in park, to 950 rpm, vibration goes away.
Also, besides previous listed items changed, I also put in a new air filter and pcv valve.
Mine does the same. Occasionally.
