olathe04si
- November 2, 2011
- Olathe, KS
- 1994 Ford Explorer EB
I know this subject has been beat to death but I'm running out of ideas. I have a 94 EB 4x4 with 182k. The car begins to vibrate around 60 and i vibrates pretty hard at 65 until around 70 when it only lightly vibrates again. It does this both when I'm on the throttle and off it. I put the car in neutral and it still vibrates the same. So far I have checked/replaced:
Front wheel bearings - replaced
Ball Joints - replaced all 4
Rear driveshaft U-Joints - replaced
Tires - replaced
Tires balanced 3 separated times after the initial balance
Driveshaft checked for balance
I put the spare on all 4 corners and the problem still persists.
I was told by my friend/mechanic that my axles, shocks, and diff mounts are all good.
My passenger radius arm bushing is bad but I didn't think that could cause this let me know if I'm wrong there. I'm running out of money and patience and I'm sure I missed somethings simple. TIA
Tires - replaced
