Well, in preparation for the installation of the steering stabilizer, I had the front two tires balanced only one week after they were just installed. As skeptical as I was, it seemed to take out 90% of the vibration. As I see it now, the tires I had replaced were definitely out of round as I saw them on a balancer numerous times and saw the top of the tire jumping up and down. So, balancing would never take out my vibration. And, there seems to be nothing major mechanically wrong, except maybe some worn bushings or a little slop in the steering box, etc. but nothing to cause the vibration I was getting. At this point, I am still getting some shimmy so I went ahead and bought the steering stablizer and it should be here tomorrow. Worse case scenario is that I am out 45 dollars and it doesn't help much other than steering jerk. Also, I haven't had the rear tires balanced again, maybe replace the third rear shock, and/or add washers to the radius arm bushings to tighten them. I suspect that the tire dealer was in a hurry, slapped the tires on, spun them once, put the weights on and put them back on the truck without checking that the tires were in fact balanced. I should have known the people who would not acknowledge that the tires could not be at fault probably couldn't balance them right anyway. By the way, I have Goodyear Wrangler RTS P235/75R15. The ones I had just replaced only had 5,000 miles before developing the problem so I hope that the new ones perform better. I will update when I install the stabilizer.
