DidiDavis
- July 18, 2010
- Davis, CA
- 1996 Explorer Eddie Bauer
I recently bought a 1996 explorer Eddie Bauer 4x4. The tires were completely worn out, so I replaced all 4 tires, and had the wheels balanced and the car aligned. I drove it in the highway and noticed a vibration starting at 75-80 mph. The whole car vibrates, but not the steering wheel. I don't know if the car was vibrating before I replaced the tires. Anyways, the vibration gets worst at 85-90 mph (haven't tried faster than that). The weird thing is that it gets worst when I release the gas pedal. Let's say I'm driving at 85 mph, if I'm accelerating, I have this vibration, and when I decelerate (release the gas pedal), it gets worst. I searched in the forum and found a similar issue related to the driveline and rear axle. However, the threads I found state that the vibration gets worst when accelerating, not decelerating.
Below are some things that I thought could be causing the problem. I'd like your ideas before I start going after this.
1- Rear wheel balancing. I don't know if the vibration would get worst when releasing the gas pedal if my rear wheels are out of balance.
2- Front shock absorber worn out. The front ones are really bad. I'll replace front and rear shocks soon.
3- This may sound weird, but could a problem with my engine mounts make the car vibrate??
4- Humm, can't think about anything else.
Any help is appreciated.
Thanks
3-
Thanks
3-
