Vibration | Ford Explorer Forums
Vibration
ranranger
NL
95 Ford RangerXL
I have a 95 ranger XL long cab has a real bad vibration between 70- 100 kl . New ujoints and center bearing mechanic says might be in rear end .
I had the same problem. I got two used tires o n the front and it fixed it. Might looking into having ur tires balanced.
i am working on that now, mine gets real bad, at about 110 k, , will keep you advised of what i find,
i already ordered the extra rear shock that goes to the frame from the rear end,
Check the tires first, balancing or bad tire.
I had a similar problem where it was between a speed range, was the front hubs
By center bearing, do you mean the carrier bearing for the driveshaft?
And by long cab, do you mean supercab, or longbed?
welcome to the forum. :thumbsup:
Sorry guys, but I meant the carrier bearing on the supercab, was replaced and I picked up a real bad vibration at45 mph I tried lining up the driveshaft but no luck
Grab the driveshaft right by the rear diff, and try to wiggle it around, to test for play. Do the same at the front end of the driveshaft, to check for play in the T-case (4wd) or trans (2wd). Also look for any dings or dents in the shaft itself, which would throw the balance off.
