Trolling
- June 11, 2010
- kah-lee-fur-nyah
is it possible to replace the drive gear on the transfer case shaft to correct the speedo after a 4406 swap?
i have the red drive gear (21 tooth) on the vss and the stock brown one on the 4406 and it reads about 4-5 mph over the true speed and that is the closest i can get it to since the red vss gear is the one with the highest number of teeth you can get without the risk of damaging the plastic gears. unless someone can find me one that has 22 teeth then that should put my speedo right on the dot. (<- that is assuming the calculator in this website is correct;http://www.cashandplay.net/CashandplayseBayGearCalculator.html; wherein my tire diameter is 28.077952755905514, my tc drive gear is 8 tooth and i have 3.73 diff gears)
so, i'm thinking of replacing the "other" gear to correct it. here's a pic of it just to be clear:
it should be an 8 teeth gear.
quick update: it looks like i need a 6 teeth drive gear (pink) to pair with the tan 19 teeth vss gear.
it's for a mustang and i don't know if it will work/fit in the 4406 drive shaft.
