Wanna run 35's | Ford Explorer Forums
Wanna run 35's
Portland, Oregon
1992 sport
I currently have a 92 sport with SL 5.5" lift and running 33x10.50/15s. I wanna run 35's I was thinking a daystar 2" spacer in the front and small blocks in the rear. Or maybe shackles? I wanna keep the suspension as soft as possible so it flexs as well as possible. I do wheel it quite offen. any ideas? L8.
I'd go w/ shackles instead of blocks. With the added 2" of lift, you could probably run 35's with some minor trimming. A better idea though would be to just do a 3" body lift instead. That gives you 3 more inches of lift without having to modify suspension parts and deal with camber or drop down brackets. Cheaper too. With the total of 8.5" of lift, you'd have a better chance of clearing 35's with less trimming.
