Want to add OEM options - switch locs? | Ford Explorer Forums
OhFourEx
Pittsburgh, PA
2007 Explorer Eddie Bauer
07 EB, but not as equipped as I'd like.
I want to add heated seats and mirrors and maybe Homelink.
Can anyone post pics of where the OEM switches are for the heated seats and the HomeLink controller? I've got a sunroof so I'm not sure if they go in the overhead console or the visor or what.
thx!:salute:
homelink i think is in the visor, heated seats is under the temp controls, heated mirrors are controlled by the rear defroster, there is no location for that.
homelink is next to the sunroof switches in the overhead counsel. Heated seats are controlled below the hvac controls lowest section in front of the shifter and slightly offset to the right, offset left would be the adjustable pedals switch and memory seat switch.
Thanks guys. I found some GIS images but wasn't sure which were applicable so that info helps.
are you going to post pictures after you are done with project with how to install oem heated seats i would like to do the same as well... thanks ohfourex
