Warm heat | Ford Explorer Forums
Warm heat
DEM723
Bellefontaine, Ohio
96 XLT 4dr (2)
I have just recently bought two 96 Explorers, both XLT 4drs with 4.0 V6 engines. Since it's gotten cold, I've found they both put out warm air from the heaters. I found one, top rad hose is only warm, and I don't know about th eother truck yet, but I suspect both need thermostats.
Unless there may be another common problem these truck have, that someone here may tell me about.
If not, then I'll plan on thermostats.
Thanks :exp:
you mean warm as opposed to hot? some people have had that problem, and replased the tstat with no luck.
