Daveymisbehavey
- January 15, 2009
- Wilkes Barre, PA
- '99 Explorer XLT
'99 Explorer XLT. When I start the truck in weather colder than 35F degrees it tends to idle like crap/barely idle/stall out. If it drop it in gear and go it's fine by the time I get to the end of my block. If I leave it idle it will run like garbage until it gets warmed up to normal operating temperature. Scanned it for codes. I have codes for bank1 lean condition, bank2 lean condition, ECT out of range, and TFT out of range. The TFT and ECT read -2C degrees and -5C degrees. The IAT was reading -11C. The actual outside temp is around 17F degrees. Am I having a problem with my ECT sensor or is it a fuel pressure problem and the codes are setting from the fact that it's way too cold in PA right now? Truck runs and drives perfect, just wont idle until you drive it about a block. After it is warmed up it will run great and idle great. I should note the timing chain is hanging on. Its making the "noise of death" but only very slightly when first started up for about 1-3 seconds. I've been running synthetic oil and lucas friction modifier ever since the noise started. I've put about 30k miles on it with no worsening of the noise. I have a feeling that the cold coupled with the heavy oil I'm using may be effecting the chain tension when it's cold out... but I'm baffled because after you start it up, the noise dissipates in less than a second but the engine continues to buck and dip and try to stall until you either drive off or warm it up by holding your foot on the gas.
Has anyone has this same issue? Or know what I should do? I've already tried cleaning the MAF and IAC. No change. HELP
-Davey
-Davey
