Lamah
- November 1, 2000
- Michigan
- 91 XLT
I like my new warns. however .... the installation sucked. i got one side done in like 10 minutes, plus the time it took to run to the store for bearings which we ended up returning. second side took about ... 6 hours ? the key was stuck, so my dad tried to chisel it a bit. then we tryed some more. then we used a drill. finnaly we found our dremel and used a diamond blade. the dremel part took about .... 30 seconds and the key FINNALY came out.
well theres my story. heh.
Jeff aka Lamah
also i have a question:
I put my hubs on and drove a bit to test them out and they seem fine. Except that it almost sounds like a rubbing sound. It sounds like it could be normal, but i'm not sure. I might have over tightened the coversion kit piece that goes closest to bearing. but that doesnt make sense since it would sound like that all the time, not just when the axles were engaged.
more i think about it, the more i think its normal, but i still figured i'd ask =/
Thanks,
Jeff aka Lamah
Jeff aka Lamah
Thanks,
Jeff aka Lamah
