BigRed
- May 17, 2001
- Toronto, Canada
- 94 XLT 4DR
I scheduled an appointment to have warranty work done on my 94 xlt 4x4 for this coming Monday. I know there is tranny fuild leaking from between the tranny and the engine and also I'll be getting the front bearings done. My concern is that the truck has 5000kms left before the Ford ESP powertrain warranty ends. Is there anything they show be checking? Guys, this is one of those "down to the wire" not much warranty left kind of things. If I can get it replaced then I'd like to do it now. What do you guys think. I'm kind of concerned about the tranny fluid leak. It doesn't leave a patch on the driveway but it is enough to concern me. Another thing, the transfer case is damp with oil around the seals. Should I request this done as well? Any input would help. Maybe some of you have had warranty work done before and can give me some suggestions. Are the dealers normally keen on going all out on these types of jobs? The warranty is an actual "Ford ESP" warranty, so I believe the dealer will probably do as much as possible as it should be billed back to Ford. By the way I bought the truck in December with 142,000 kms on it and purchased the warranty then. I look forward to your responses. Thanks for everything guys!!!!!!
