Warrior Quick Disconnects finally on! | Ford Explorer Forums
JamminG4Jim
Near St. Paul, MN.
2000 Sport
With a little help from a friend we finally got a sunny day and put on the quick disconnects. The front set went in pretty smoothly. The rears were a different story. The warrior link arms do not angle the same as the superlift extended link arms we removed. They were a little tricky to get on where the bolts wouldn't hit the spring leafs.
Mission accomplished. Now I have to get used to hearing the quick release pins rattling on the link arms!
I AM glad it's done,tho. Unbolting them on the trail is a major pain. NOT having to Keep track of all the bolts,washers, etc. makes the price of the quick D's worth it!!!
Jim
Why are you even running a sway bar in the rear? I haven't had mine on for two years. I can see the front one because it does get squarely.
I just made my own for the front.
You are right, it is a lot easier just pulling a pin instead of unbolting.
Jim I just got some skyjacker 6" links from Tdavis and used a pin instead of a bolt, works like a charm, and YES it is all over hell without a sway bar. Gotta agree, I hate those superlift bar relocation brackets for the front.
