Warrior Quick Disconnects | Ford Explorer Forums
Buds007
Provo, Utah
97 xlt 4 door
Who has a 95 and up Explorer that is running the warrior quick disconnects. I was looking at them, and they seemed to be very nice. How well do they work, and is it noticeable. Where would I find these, and how much are they. Thanks
I'm using them on a 94. They're the same in the rear, and mostly the same in the front. They work great to take them off, but after an Ohio winter they've became hard to put on. Still easier then a wrench and cleaner than a cotter pin IMHO. Check out 4wp, and if you buy there don't forget the discount.
I ordered them yesterday. should be here in a week. should be the same effect as using poly bushings as far as ride goes. as far as ease of disconnect/reconnect ill have to see........
I have them on my 97, and they work great. Easy to take off and once you grease the sway bar they are pretty easy to put back on. Worth the money in my humble opinion.
How Much were they and where did you buy them
$79.95 from www.central4wd.com. I actually had to call and order it from them. So Ray when I get a lift I can just get a longer post link from warrior huh...
Troy,
You can make the tube yourself, just buy some pipe the same diameter as the old tube and cut it to the length you want. put the ends in and drill the holes, then just paint it and you're good to go. :)
