- November 6, 2000
- 2018 EX Sport Concept
shore
Far as I'm concerned, the warriors with the monoleaf is the bomb setup for good flex and small lift. so yes, just buy the war153s and twist the bars to your liking..you get a bit more height (more on the sport) for $50..and the performance of the suspension should be better...not to mention the extra flex for wheelin. Its been mentioned that add-a-leaf or even just swapping out to a leaf pack is possible, but I wouldnt advise it. You can get the stronger coded torsion bars if you need more lift in the front, but I think you can get all you need with the softer bars, and it might even be better since the "softer" bar will probably ride pretty good even when cranked for height...just try it first, and if it doesnt suit your needs, you can always upgrade later..dont spend the money before you are sure you need to. You should also consider upgrading to better/newer shocks to compliment your new suspension upgrades.
Originally posted by kps36
It has a SINGLE (monoleaf) leaf for the rear. Can I do an add-a-leaf? Should I just stick to WAR153s and do the 'twist' to the front?
