Water Leak | Ford Explorer Forums
Water Leak
Tyleryac
NJ
2005 Ford Explorer XLT
I have water coming in on my driver's side floorboard. Where would I go to get something like this fixed?
Tyler if it's rainwater, try Safelite Auto Glass if the windshield leaks. AC condensate or moon roof drains are another possibility.
I fixed the sunroof drains myself so it's not that. I pulled up the carpet one day and when I ran water down the drain under the windshield, water came in.
If your driver side carpet still gets wet, check the thread link below and look at post #29 with the photos I took. Water can also work it's way into the vehicle and run down the inside firewall (behind and above the foot pedals) when the inner cowl/fender drains get plugged with leaves and debris as the pics will show.
try this link below :
http://www.explorerforum.com/forums/showthread.php?p=3216684#post3216684
I was able to fix it. In total the repair took me about an hour. Thanks for your help guys!
So where exactly was the water leaking in from or what caused it to leak in the first place (Ex: plugged up fender drain holes as in my case) and what did you have to do to stop the leak?
Tit was the same exact thing you had as mentioned in the link provided ^
