okxlt2003
- December 30, 2010
- Altus Oklahoma
- 2003 XLT
My 2003 4.0 started leaking water, what appeared to be about half way down the right front of the engine. (behind the alternator bracket) At first I thought it was the water pump, since I haven't changed one on it and it has 194,000 on it. So I swapped out a new water pump. It still leaking!!! More investigation I found out the thermostat lower water outlet was the culprit. Replaced the water outlet, thermostat, thermostat cap, all the seals and the bypass hose. Everything is fine now No leaks.
