SouthernSAR
- December 21, 2011
- Naples, FL
- 2004 Explorer ST XLS
So I haven't been here in a longggg while. Which is sort of a good thing I guess, because I mainly came here for help. Seeing as I hadn't needed any help because everything was running fine, well, you get the idea. But I'm back. I've had my rear seats out for some time now (building a sub box to go back there), and the other day I noticed I've been getting some water in the back of the truck. I decided to try to find the root of the problem, and remembered that the third brake lights have occasional issues. I sprayed mine with a hose and found that water was leaking into the cab and becoming visible on the passenger side, right by the rear window motor (actually all over the motor
). I took off the third brake light and checked for signs of a leak, but found nothing. I'm wondering if it's coming in from the rear window, but I haven't done anything to that recently...
Does anyone have any experience with this, or have a solution to this problem? It's been raining literally every day here for a few weeks, and it will be continuing to rain. I need to find a way to fix this because I don't have an indoor place to store my truck
