jseabolt
- July 12, 2009
- Kingsport, Tennessee
- 2006 Explorer Limted V8
2006 Explorer 4.6 liter, 131K miles:
This makes the second time this has happened. The first time this happened I replaced the #4 spark plug because I thought it was defective. Because when I did a tuneup about a year ago, the #2 Autolite sparkplug was bad straight out of the box.
A couple of months ago my Explorer developed a #4 missfire. When I replaced plug I noticed condensation in the boot. I did a taste test and confirmed it was not antifreeze. Yeah I know that is probably not the best way to identify a liquid but...
No missfires for awhile.
So it came a hard rain last week. The nose of the car was pointed uphill. The next day my Explorer developed a nasty missfire at idle. Eventually the check engine light came on. So I was going down the road and decided to "floor it" to see if this would clear it. Wishful thinking I guess.
So now then the check engine light starts flashing indicating a "really bad" misfire. After I slowed down the check engine light stopped flashing and then went off.
Got home, connected my code reader and just like before it's the #4 cylinder.
By the way, for those that don't know, #4 is the plug at the back of the engine on the passenger side.
Last time I installed a Motorcraft plug in the #4 cylinder since the new plugs I installed a few thousand miles ago were Autolites and I got a defective plug. They are probably the same plug, just rebranded.
So I called a buddy who is a mechanic at a Ford dealership and asked his opinion to see what might be the most likely cause, bad coil, bad injector or another bad sparkplug.
He told me what happens is rainwater leaks off the cowl and makes a straight shot into the #4 plug well. I told him that I noticed condensation when I replaced the plug the last time and wondered why it was there.
So the next day I pulled the coil/boot off the plug, sprayed some WD-40 into the boot and around the plug and blew it out with compressed air. Now the missfire is gone.
My buddy says to run a bead of silicone somewhere off the cowl panel and create a tail which directs rainwater away from the #4 sparkplug hole. But I cannot visualize what he is talking about. Anyone know about this "fix". Is this from a tech bulletin sent out by Ford or a fix him or a mechanic at his dealership came up with? I did not want to ask him.
I did discover two drain holes in the lip of cowl panel above the engine where water could possibly leak into the spark plug hole. There is actually four of them. Two in the middle and one on each end.
I took some alumnium tape and covered the center holes up that are in the middle from underneath. That way any water that collected in the lip would run toward the holes at the ends.
It came another hard rain a couple of days later. This time the nose was pointed downhill. So I would expect under this condition water would be more prone to leak but the next day there was no missfire. So I assume the plugging up the two drain holes in the cowl lip may have fixed the problem.
If this happens again, before I dry out the plug boot with WD-40, I'm going to open the hood and lay a water hose on the roof and flood the cowl panel to see if I can tell how water could be getting into the engine compartment. There is a rubber seal between the cowl and hood and it appears to be making a good seal. But may not be. I suppose I can always lay an extra piece of foam rubber under the hood to make a tighter seal.
Anybody have any experience with this same problem. How they fixed it?
