walterd140
- August 9, 2003
- Ludlow, Massachusetts
- '94 Sport
Got a leak at / near the water pump & I don't know if it is the heater hose or bleed port. Where is the water pump bleed port located as I look down into the front of the motor? 12 o'clock being the top of the pump, 9 o'clock the passanger side of the x.
Any help? Fluid dripping at about the heater hose connection at about 10 o'clock. If I can locate the bleed, then I can figure out what is the issue (hose or pump)
Walter
Walter
