Weird A/C Problem | Ford Explorer Forums
Weird A/C Problem
isuballr
Arlington Heights, IL
'97 AWD Eddie Bauer
Hello all. I have an odd problem with my AC. I turn it on and it works for about 30 seconds or so, then there is a loud SLAP behind the dashboard, on the passenger side, and it blows out hot air. I can turn it off, then turn the AC back on and get the same thing...30 seconds of heaven, then SLAP, blowing heat again. Any thoughts or ideas?
Thanks
You most likely have a blender problem... lots of posts in both the ac forum and in the "vehicle year" forums.
There is a repair kit for this problem I've seen somewhere. Do some research on it is all I can tell you!
I was pointed to some A/C Guru's at the Automotive A/C Information Forum :thumbsup:
You have to go through the usual sign up process and you are all set.
The link below will take you there.
http://www.autoacforum.com/index.cfm?NoCookies=Yes
Good luck.
Rick
