Joe Dirt
- October 4, 2007
- 07 Camry
So a while back, I replaced the front driver side wheel bearing on Snowball. I think the ABS sensor had been removed then reinstalled, as there was some RTV around it. The hub was newer when I pulled it at the junkyard.
Fine for 3 months.
Now, when coming up to a light (even when dry) my ABS will engage from like 5 mph to zero. Sometimes when traveling straight, mostly when coming to a corner when turning right, so the wheel is turned.
Could this be something awry with the sensor if it had been removed/cracked somehow? ABS functions fine otherwise, and there are no codes.
TIA!
Fine for 3 months.
TIA!
