joeclark
- August 9, 2015
- Kingsbury, TX
- 1998 Ford Explorer
OK I just bought this 98 Explorer XLT and it had several small issues most of which when i fix one it brings up another.
First the dome lights would not come on when i opened the driver's door but would with the other 4 doors so i found that the door switch is in the door. Pulled the panel and found that the switch was unplugged. i re plugged the switch and the chiming started, at first i thought i left the keys in the ignition but they were not there. i put the door back together and in the process rolled the window down and noticed i could roll all of the windows down. and yes the radio works too. (it is an aftermarket and i just figured the PO wired it direct, now not so sure)
i tried checking the little tab thing near the ignition lock cylinder but it still chimes even when it is removed.
I also tried disconnecting the plug to the ignition switch thinking it was stuck with the accessory mode. but when unplugging it still continues to chime.
this is where i am at a loss. the fact that the radio stays on does not bother me i don't have an issue with remembering to turn it off, but the chiming every time the door is opened (unless the key is in the run position) is really annoying. that and the fact that you can roll the windows down while the car is off. i am pretty sure these are the battery drain issues that the PO warned me about.
