jlk112678
- January 11, 2012
- 1991 Ford Explorer
I have a 96 exploder 4.0,all through the winter no problems,as soon as it got hot out(not mornings or evenings though)it runs for a while than wants to stall,if I pull over and pour a gallon of water on the top of the engine and l sit for 10 min it will start back up and run for about 45 min before having to repeat the process.
I have replaced the fuel pump,fuel filter,antifreeze,thermostat,radiator cap.It acts like vapor lock because of it stalling and not wanting to start when hot and then pouring water on it cools the fuel rail,and it starts up.
So I guess my Question would be,Is it vapor lock,is there something else causing this,could my intake manifold not getting enough coolant?I really need some help with matter! :exp:
