ForFun
- February 15, 2014
- 97 4.0 OHV 4WD
I would appreciate any feedback on this issue. I have a 1997 4.0 OHV that is throwing P0171 and P0174 codes, and the scan tool data is unusual.
Looking at OBD live data, the STFT and LTFT both show -100.0 for bank 1 and 2. Not changing with time or RPM. Also, O2 sensors are registering 0V, with no movement.
I'm wondering if there is something stopping the PCM from sending data on these sensors.
I've used various scan tools, all show the same. Also checked other vehicles with the scan tools and get sensible readings.
Fuel pressure reads 32PSI Key in Engine Off, and 35PSI with engine running.
Coolant 192F. MAF 0.62 lb/min (3.56 g/s)
I've replaced the PCV valve and the connecting hose with OEM parts.
I can't really move ahead with any more diagnostics until I figure out this weird STFT/LTFT and O2 sensor data. Any suggestions?
Thanks!
Thanks!
