G
geoph1986
Hey everyone...here's what's going on. I pulled apart my dash today to run wiring for my upcoming carputer project. When i removed the instrument cluster I found 2 mystery wires that went to nothing, they were just cut off and left hanging. Both of theses wires are spliced into the harnesses that plug into the cluster. The first mystery wire is on the black harness (closest to driver's side), tapped into the "black with white stripe" wire. The second is on the grey harness (closest to center console), tapped into the "grey with white stripe" wire. The original wires seem to still go where they are supposed to, but the mystery wires go nowhere. Also, on the cluster itself, someone has removed the "check engine" & the "amp" bulbs. I have a feeling that these two things are related and I need to know what those original wires are for. I always thought it was weird that the check engine and amp lights didn't light up when I turned the key to the run position, but I thought that the bulbs were probably burnt out. The truck seems to run fine. The alternator gauge shows charging. Any help on this would be great, and sorry about the long winded post. Thanks.
