For a 9" you don't have a choice since its hard to really weld it. I was riding with Firezapper when the mini spool let go. The 8.8 design really sucks and if there is ANY slop at all (I'm talking thousandths of an inch) between the center and outter blocks the mini spool will eat itself, which in turn will eventually break the cross pin. I wish I'd had a chance to take a picture of the damaged mini spool, but when trying to fix the thing along side the road I didn't cross my mind. We got lucky and an RRORC member lived close by and he brought a new cross pin. I had to remove the carrier and take the ring gear off and put in the cross pin to capture the axles just to get home. Its by far an inferior setup IMO.
On my 86 Ranger I ran a welded front and rear diff and never had a problem with it. When I pulled the truck up from OK to IA it was unknown to me at the time that there was very little oil in the rear diff. This in turn at the cross pin almost in 2 and it could not be removed. After welding the rear axle was stronger than it was stock. The trick to doing it is knowing the property of the metals involved, mainly cast steel. Because cast steel and other steels are different they cool at different rates, thus causing welding problems as they contract at different rates causing stress fractures. The best way is to take a torch and preheat the area that you're going to be working in. Get everything up to a constant temp and stop every now and then to reheat to keep it hot. Ideally use a stick welder with (I believe, but its been a few years since I've done it) a high nickel rod. Make multiple passes to build up the weld area. The spiders should be welded together where they mesh, and welded to where they meet the carrier. After that do a post heat to make sure everything is at the same temp. When done you should use ideally a brine solution, but an oil will work. This will help to keep the heat in the carrier and gears to lessen the effect of cooldown between the cast and non cast metal. In 5000 miles I never had a problem with it and even after the offroad trips they still look like the day I welded them. The front has survived having a hub blow, yoke rip apart, and the same short side shaft break its splines off in the case all at the same time. The only reason I'm not welding my 9" and D44 is that I can't do the 9", but the 44 I decided to do the full spool since I need a new carrier anyhow and its not much more.
