who says its wouldn't be functional?
Because it
wouldn't be functional on an X. That's just ricetastic/crapstastic IMO along the lines of "Explorer" chrome cladding, curb feelers, 6 inch fart cans and blue neon undercar lighting.
and actually in that case why would anyone put a scoop on there vehicle unless they have a top mount intercooler?
Good point. That's what I'm trying to say. They would. My Legacy has it as OEM equipment because of yes, a TMIC. Retrofitment/aftermarket for a TMIC or RAM air on a highly modified car is another issue.
my buddies cuda was on the dyno and factory it had a functional ram air but it restricted the intake flow which caused a lose in hp. the old believe was a hood scoop would i'mprove performance do to better air flow then it was looked at again and completely flopped.
Maybe so in the Cuda. Not necessarily true of others from the muscle car era or well engineered solutions (e.g., T/A RA, GN headlight RA, etc.). Don't no for sure. Could be bad OEM design, highly modified engine in your buddy's case requiring substantial additional airflow - don't have enough information.
you lose hp if you use your scoop as an intake. think about it head rises and your hood is above the engine so it heats up pretty dam fast. this would cause the intake heat to be much higher.
Your argument there doesn't hold much water. Making a blanket statement like that doesn't fly in every properly engineered situation. At speed, the benefits (read compression) of air will more than make up for any slight, actually negligible, increase air temp from a scoop in most cases.
the only use for a functional scoop on a N/A vehicle is looks
Well, that's my point - ricestastic. That does
not equal function. It equals aesthetics (or lack thereof). But who am I to judge? Just my opinion, nothing more.
, heat reduction, fix clearance issues or if you just want to make your engine a hell of alot dirtier. so in the end you can make it functional but it is pointless so for looks why not. hell 99 percent of cars from the factory these days that have scoops aren't functional
Heat reduction for an air scoop? Not really. Negligible. Clearance issues back in the blower days or custom CAI? Yes.
If I've offended anyone, I apologize in advance. Again, this is just one man's opinion
