Wet drivers floor? | Ford Explorer Forums
Wet drivers floor?
302w
PA
1999 Mountie
What can cause a wet drivers floor when it rains?
My sunroof appears to not leak. I blew out the lines, and I would assume water would hit me while driving if it was leaking. Suggestions?
Maby a hole under the drivers side foor well. Or check the seal around the windshield. Had a similier issue
Is the headliner wet? if so then its with the sunroof
Does the floor get wet while driving? if so then its something with the floor
Ive done alot of searching about this.
Check the corner of the windshield by removing the plastic trim under the windshield wipers.
Or
There is a spot on the firewall that needs some caulking. Look up under the dash and have someone spray water and follow it down.
No dripping through the headliner at this time. I will look into this, thanks guys.
