What can I do to my Explorer? | Ford Explorer Forums
93'4x4Explorer
Chattanooga, Tennessee
'93 Eddie
I want to know all I can do to my '93 Eddie Bauer Ford Explorer. Whats a good lift kit to get and size of tires to put underneath my SUV.
first of all welcome to the site and second of all, use the search feature. the possibilities are endless, just use your imagination. i think there is a tire part on this forum that will tell you pretty much all you need to know about sizes and then just search for lift kits......
First welcome to the site, you are definitely at the right place if you want to modify your X !I guess you are looking for engine mods also? I assume its stock,I,d start with a good intake kit like a K&N FIPK or a KKM filter kit. upgrading your exhaust will help also,alot of people on this site are running Flowmaster mufflers,(which will be my next mod)depending on what size tires you want to run there are many suspension lifts available and body lifts ,a cheap and easy lift for you would be to install lift shackles and add a leaf for your rear axle and 2inch coil spacers up front,then you could easily fit 31's , you would be surprised at how much better your X would be offroad with those simple mods.Try the search feature for certain mods you are thinking of,you will find more than enough info.
good luck, Matt
Dead Link Removed
this should help you out alot. welcome to the site!!!
