What causes this?? | Ford Explorer Forums
What causes this??
JayRenae
2002 Ford Sport Trac
So I have a 2001 Trac and its been acting weird... Whenever I go up a hill or speed up fast it jumps.. Its almost like its struggling to go.. I replaced the spark plugs and spark plug wires cause that's what I was told to do... But it hasn't done any good... Any ideas on what it could be or why its happening... Thanks in advance!
Id check the fuel system... fuel filter was clogged on mine and caused this similar reaction
Better to check your fuel pressure before and after replacing the fuel filter. If pressure gets better after replacing you found your problem otherwise it could be fuel pump or fuel pressure regulator.
