burningbilly
- March 21, 2008
- new brunswick canada
- 94 eddie bauer
ok hi all i never should have sold my 94 ex because now i have a 92 ex and it is in rough shape. i have so far shanged the following trying to fix my problem's. so hopefully i dont confuse all of you and maybe you will know something that might help.
Firt off fuel pump rusted out on top of the tank. ok not a problem ha. ended up changing fuel lines, fuel pump and fuel filter. ok worked good for a day. then rough idle started. that was a month ago. since then new plugs, wires, new fuel lines to the plenium. new intake upper gasket and pleniu gasket. or what ever it was called. both gaskets though in betwwwn the intake fuel rail and head. so it worked good until it rained. then rough idle and stalls. so i took the intake off and grabed a can of fuel injector cleaner and started scrubbing. cleaned iintake and soaked injectors in it and tapped them clean. alot of junk came out. put it all back together and it ran great till yesterday., of course when it rained again. i am leaning to possible coil pack pro as it worked great till the air was really muggy. causing moisture everywhere, maybe there is a pin hole leak or something.
HELP
help
help please
also i dont have a fuel pressure regulator tester here so i put a new 1 of those on this morning and nothing.
HELP
help
help please
