What is this part? (see picture) | Ford Explorer Forums
97splorer
Overland Park, Kansas
'97 XLT 5.0 AWD
I have this ticking noise in the engine that sounds like it's coming from the EGR area. The other day it became very noticable, upon further inspection I noticed that a vaccum hose came off the egr tube. Anywho, I re-attached the hose and I still get a ticking sound I traced it using a steel tube against my ear and this part seems to be making the noise I hear...
vbgarage.php
What is this and would it be making a ticking noise, almost like an exhaust leak?
It sits just behind and under the EGR right bhind the intake. (5.0 engine)
Any ideas?
Thanks,
Brian
i dont know, but it looks vacuum related by the connector on top of it... that doesnt appear to be an electrical connector
Where abouts is that?
looks like the fuel pressure regulator
a million dollars question here... I DO NOT KNOW! LOL
the ticking is most likely an exhaust leak commin to the 5.0's
that picture is of the FPR just like stated above.
It is VERY possible the ticking is an exhaust leak.
I have the same ticking on my 96 Explorer 5.0L, definatley an exhaust leak on the passenger side exhaust manifold. When I tore down my 97 5.0L engine I found all the exhaust maniold bolts were merly finger tight, they come loose, it leaks.
So the noise I hear thru the bar is not actually the Fuel pressure regulator, but the exhaust leak around it? When I move the bar around the engine, exhaust, etc. I do not hear the ticking thru it, but when I put it on the FPR and listen, it ticks. Is that normal?
