What is this part?? | Ford Explorer Forums
What is this part??
03Explo20
Jonestown, Pa.
2003 Explorer XLT
Located just under the master cylinder mounted to the inner fender well.
Purge valve for the EVAP system?
drdoom, if you say so! :) I broke off the lower tab while installing my struts yesterday and was wondering if it might cause me a problem. I was able to put the upper mounting bolt back in and tighten it all down but that lower mount snapped.
If it's secure you are probably OK, if there's a system breach it will set a trouble code. Best wishes.
I know it's too little too late, but I was able to just release a catch and slide it up... No need to unbolt it.
I, too, recently changed my struts...
I thought I had enough room to get the extension down behind that but apparently I didn't! I bolted it back up tight and will just see if it throws an error code. Part is only about $50 if it needs replaced.
Thanks guys!
