Vacuum lines
The photos were a big help Gilly! I wish that my engine looked as clean as yours! I should order some powder coated valve covers to dress mine up a little.
I believe that the photo below identifies the vacuum lines in question.
Red arrow: Connection to upper intake manifold port located at right rear. Single large hose connection actually has three internal semi-rigid hoses.
Green arrow: One of the three lines is divided into two lines making a total of 4 lines in the bundle
Yellow arrow: Two vacuum lines turn toward left side of engine compartment joining the one from the EVR to the EGR valve. One goes to the fuel pressure damper (regulator in your case). The other goes to the lower left front of vehicle below the battery. I think it is connected to the fuel vapor management valve. Two vacuum lines turn toward the right side of engine compartment. One goes to the EVR. The other goes to the lower right front of vehicle below the air filter enclosure mount. I think it is connected to a metal bulb that acts as a vacuum reservoir.
Blue arrow: The connections to the EVR
Black arrow: The line going to the vacuum reservoir bulb
The EVR electrical connector is above and left of the blue arrow in the photo.
Let me know what else you need. My engine will probably be apart for the next few weeks while I assess and correct my timing chain issues.
