No extreme heavy duty mods, auto shift and auto tcase, hell yeah reliable, drove it 4 hour round trip alota times with only one problem, someone in passenger seat *****ing all the time. lol. This is everything Ive done to it that I can remember, well the painting certain parts aint on there.
Dr/Ps Front Wheel Bearings
~Both Retightened on 02/07/09
Rear Brake Line.. All the way 9-15-08
Some Body Work
Door Pins
Poly Radius Bushings 11-29-08
Rear Drive Shaft 1/09
Warrior Shackles (replacements) 9-05-08
9004k Light Bulbs 9-01-08
Rear Door Shock ReWeld 11/08
Starter 2006
Oil/Filter Change @213k Normal 5w/30
Oil/Filter Change @217k Synthetic 5w/30
Tire Alignment 11/08
31s + mounted 11/08
Rear View Mirror 2-09-09
Front Brake Pads 11/08
Stock Muffler and Piping 10-15-08
Magnaflow Performance Muffler 2/09
Air Filter 213k
3rd Row Seat; 3-30-09
Tune Up (wires/plugs); 2215xx miles
PCV Valve; 3-17-09
O2 Sensors x2; 3-1-09
Tranny Line Cooler; 3-17-09
~Filter Kit
~Fluid; 4 qts Syn Fluid
Fuel Filter; 3-1-09
Brake Job; 2-22-09
~2 rotors;
~2 Calipers;
~Rear Brakes;
~Rear Brake Hardware Kit;
~Driver Side Brake Hose;
Front Differential Fluid; 2-27-09
-Synthetic 75/140 M1
Front Sway Bar Extenders 3-17-09
Bump Stops; Polyurethane 10-23-09
Sway Bar Bushings; Poly 4-16-09
Ext Brake Lines Front/Rear
4” Susp Lift Kit; 3-1-09
~Complete Kit;
~Shock Boots;
~Alignment;
Extended Center Console; 10/08
6.5" In door, 6x9 in cargo, 5.25" rear doors, 3.5" in center ext.
Reconnected seat to metal (where it bolts to floor in front) with plumber strap.
Rear Light Guards
Lock Covers (Bullets)
Red Top Optima (from previous cars)
Tcase Shift Motor Fixed ; 4/23/09
Rear Diff Fluid/Painted; 5/12/09
New Head Light Set
Fire Extinguisher
Cargo Cover
Thermostat + Rad Fluid Flush 2215xx
Alternator Wire 4GA upgrade
Snorkel 10/28/09
Car Audio Pos/Neg Bat Adapters
