Jet Ski Puller
- May 2, 2001
- Clinton, UT
- '08 Sport Trac 4.6
It looks like I may have a clogged cat . . . if so, I'm going to have it replaced with a 3" high flow unit.
So, I thought at the same time I would have the performance shop fabricate and replace the rest of the system. They are recommending a Dynomax Turbo muffler. I know there are a lot of opinions out there as to which muffler is best. I've done a search and read many responses.
My question is . . . What size are all these aftermarket systems? I've found a Gibson on line and it is 2.5" and a generic on Exp Express and it is 2.25". Couldn't find anymore info.
My truck is basically stock, have an AMSOIL filter that flows more air than stock and at some point MAY change out the MAS and Throttle Body, but this is not for sure.
I do a lot of towing, so I need the torque.
What size tubing should I have them use?
Thanks.
Thanks.
