- January 22, 2007
- selkirk, manitoba
- 98 supercharged 347 sport
this is staring to drive me nuts. just did my 8v swap in my sport. according to this thread (around the 10th post)
http://www.explorerforum.com/forums/showthread.php?t=209963
so i pulled that wire out of the connector
but when i went to put it into the 16 pin connector it was like this
going from a thread that corkey found for me from TRS, it should look like this
im a tad stumped here. can anyone help? i DO NOT want to either put that wire in the wrong spot, or ground it incorrectly in fear of blowing something that i will need. the truck is a 98 sport that had a SOHC in it, and the motor is also from a 98. i tried changing the circuit boards on the back of the cluster, and that didn't work. i also tried the cluster from the v8 truck, and that also didn't work. the tach reads way to fast, and want it to read correctly.
I can save you some research.
On the back of the cluster are 3 connectors, 10-, 12- and 16-pin. Look at the short 10-pin and you will see a black/yellow ground wire in pin position #8. Now look at the 16-pin and you will see an empty slot in position #16. Release the black/yellow ground wire from the 10-pin and move it to the #16 slot of the 16-pin. That's all it takes to convert your V6 truck to read V8 RPM.
