What's the biggest tire size I can put on stock rims without needing speedo gear swap | Ford Explorer Forums
Vikram
1995 Ford Explorer XLT 4W
Want to get bigger tires and saw the thread here showing biggest tire u can put on stock height... But what is the biggest tire size I can put on my stock 15" wheels without needing to change my speedo gear?
It's all here ...
Dead Link Removed
Fair enough, try this as well ...
http://www.explorerforum.com/forums/showthread.php?t=158739&highlight=gear+chart
This offer the part numbers, number of teeth, and the math to figure out how much correction is needed based on the tire size change. You should be able to pull it together from there.
Here's a broader list of links about tire sizes and speedo gears (among other things)
http://www.explorerforum.com/forums/showthread.php?t=216933
There's great stuff here. All you have to do is dig a little.
:exp:
Any change of the tyre size will effect the speedo.
Your speedo won't be accurate anyway.
