doonze
- May 16, 2009
- Fayetteville, Ar
- '93 X Sport
So, as I'm out and about working on the truck today I was using my 2 1/4 ton floor jack to help me with the exhaust. I've only ever used it on cars before, so I decided to make sure it had enough reach to get my trucks tires off the ground. Well at least on the front that won't be a problem I discovered, however while I had the tire off the ground decided to give it a spin....
It moved the whole of about 4 inches after I let it go and stopped....Hmmmm.... It should spin more then that I'd think.... So I play around with it.....nope, there's drag there for sure.
So I jack the drives side tire up.... give it a spin, it spins at least 3 times around before stopping... feels like it has much less resistance. I yank around on the tire too, to see if I get any movement of the wheel....none. Lower that side back down.
Jack back up the passenger side.... Moved better, spins at least 1 time around now, then I start yanking on it...there's a bit of movement. If I yank on 12 O'clock or 6 O'Clock it moves slightly, 3 and 9 are ok. When I look on the inside doesn't seem anything in the linkages is moving, nor the knuckle. Just the wheel...
Could this be wheel bearings?? Any ideas what else if not?? Oh, and after yanking on it, the spin was back to a few inches after letting go. I know my breaks could be grabbing lightly, but if not that I'm looking for ideas. Never done wheel bearings, never had too.
