Wheel swap | Ford Explorer Forums
Wheel swap
J'sLilMonster
Tyler, Texas
1994 Ford Explorer 4x4
I'm wanted to swap my 15" factory wheels to something a little larger and easier to find mud grips for. I've found some info about other makes and models of vehicles with the same size lug pattern and center bore. But my question is, can anyone tell me a few common vehicles that have 5x4.5 with a 70.3mm center bore or somewhere that I can what I'm looking for. My next question, does anyone know right off hand if the wheels from a 2009 Wrangler Rubicon will fit?
Last year for the Wrangler to use 5x4.5 was 2006.
I used 16" Sport Trac wheels for a while but had to use 1" bolt-on extensions/wideners. They worked great but were a little annoying to remove when doing suspension/brake rotor maintenance, I had to have my wife hold the brake pedal to install and remove the extensions.
