It can be difficult to pin a mileage figure to something so drastically affected by climatic conditions - where I live we have 90+° all the way to -40°. Three seasonal changes should be about enough. "Thermocycles" are an intrinsic and decisive factor in motor vehicle maintenance. In the winter, my motor goes from -40 to +200 a couple/three times a day.
It's tough to put a mileage factor to water pumps - some exhibit premature pattern failures, some last the life of the vehicle, and some just bite the big green wiener. Water pumps "generally" (note the quote) give plenty of warning when failure is imminent - but we have to heed these warnings.
Water pump failures can include the seal/bearing (allowing coolant to escape through the "weep" hole), impeller failure (loose on shaft), impeller failure (vane erosion due to chemical reaction), among many others.
While we're on cooling systems.... specific gravity (antifreeze content) of the coolant will have an effect on coolant temp sensors. Antifreeze not only modifies the freezing point of your coolant, it also modifies the "boiling" point, corrosion properites and flow (viscosity) all without changing the Ph properties of your initial water content...... which may or may not be chock full of calcium, potassium and/or other minerals/chemicals (some of which will be added by your local water authority - they like calcium and such to plug the pinholes in old, leaky water mains).Calcium, et al, will also seal off those pesky leaks in our cooling system....like the ones between our header tanks and the rad core....
